I've doubts about this circuit. The 2 transistors are matched in saturation, and the book I follow neglects channel modulation. The author considers as input signals VGS1 = VGS0 + Vin/2 and VGS2 = VGS0 - Vin/2 where VGS0 is the common mode and Vin is the differential signal. He considers as output of the circuit the difference between the two currents, that is I1 - I2
Now, the author writes:
If I make some computation, I get a different expression of I1+I2, which contains this quantity: [(Vin)^2]/2
If I neglect this term, I get the same expression of the book, so the first question is: Why does the author neglect this term? Then the author makes a simplified small signal circuit, which is the following:
He applies a common mode signal and he gets that the common mode current is:
iCM = (gm x vCM)/(1 + 2 X gm x r1)
Then he says that iCM is approximately equal to vin/(2 x r1)
That's the second question: why does he do this approximation?
You can find the book reference here:
Thank you! Stefano
