I'd like to print value of Revision variable that can be set in Project Options - Parameters (not Document Options on Parameters tab) into silkscreen of PCB. How could I do this?
trying to get value of parameter
8
I don't believe you can print schematic document parameters on the PCB silkscreen. However, if you add it as a project parameter than you can use the syntax '.ParameterName' to print in silkscreen.
Project Parameter Setup: enter image description here
PCB Silkscreen Setup: enter image description here
Resulting Silkscreen: enter image description here
  • \$\begingroup\$ I'd just like to mention here that you may see text '.PCB_number' while designing but it will render with value - you can see it in 3D view. \$\endgroup\$
    – mitjajez
    May 11, 2018 at 9:46
    \$\begingroup\$ @mitjajez If you click the colored "Current Layer" box at the bottom of the editor next to your layers and switch to the "View Options" tab you can check the "Convert Special Strings" box under "Display Options" to show the rendered text real-time. \$\endgroup\$
    – DerStrom8
    May 11, 2018 at 10:42
There can be also name of Output set with Project Propertie like =Parameter+' other part of name'
