I am using piezo speakers as pickup for my guitar. In one setup, for an amp, I have a 25 year old Philips powerhouse aw636 stereo, which has a mic in. The problem is that when I connect the piezo to the mic in on the stereo, there is a buzz, and it goes away if I touch the negative tip of the jack. A microphone from Philips works fine, without any hiss, but not the piezo by itself.
I was trying to remove the buzz/hiss from the setup using capacitors (trying to create grounding) but that never worked...
What can I do so that I don't have to connect my body to the jack -ve to remove the hiss?
The piezo pickups work fine without hiss when I connect them to the computer's mic in jack for amplification. The piezo in use a 35mm one.
EDIT:
One of the comments was an answer, that by Tony Stewart.
It says:
Use a large CM choke which balances the 2 wire impedance by raising CM Z while not raising differential Z.
