I came across the following appnote(slyt647) which analyses the two op-amp instrumentation amplifier topology.
The gain was found by finding individual gains for each op-amp and adding them in accordance to superposition. I have some hard time understading how \$G_{A1V-IN} \$ (eq 8) was calculated. Circuit Diagram
As far as I see it for \$G_{A1V-IN} \$ we have the following equivalent circuit:
And thus it seems to me that: $$G_{A1V-IN} = -\frac{R_R}{R_G} -\frac{R_R}{R_f}\cdot \left(1+\frac{R_R}{R_f || R_G} \right) $$
Did I go wrong somewhere ?
You're right, they ignored Rg in A2 gain. I tried to sum the currents in A1- node, I made the same mistake and I've got the same result.
  • \$\begingroup\$ Oops... Now i've fixed it. This doesn't really answer the question though. Why does the gain term in the appnote neglect this part ? \$\endgroup\$
    – Mike
    May 14, 2018 at 18:03
