This seems very counter intuitive to me. How can increasing capacitance value make the circuit more inductive ? The math tells me so :
If \$C\$ increases then \$X_c = \dfrac{1}{\omega C}\$ decreases, so the circuit becomes more inductive.
But I've heard that factories that use heavy motors have a large \$X_L\$. For this reason they need to increase \$X_C\$ so that \$X_L = X_C\$. To increase \$X_C\$ they seem to "add" capacitors. But adding capacitors actually decreases \$X_C\$ right ? \$X_C \propto \dfrac{1}{C}\$. How does this work ?
Definitions :
\$X_C\gt X_L\$ : more capacitive circuit
\$X_L\gt X_C\$ : more inductive circuit
    \$\begingroup\$ Depends how you add them! Think about how capacitance gets bigger. \$\endgroup\$ May 14, 2018 at 14:30
    \$\begingroup\$ Then your circuit is inductive. Power is going back and forth between source and inductor. Add any capacitor and now some of that power goes between capacitor and inductor. \$\endgroup\$ May 14, 2018 at 14:34
    \$\begingroup\$ With heavy motors, you aren't increasing series capacitance. \$\endgroup\$
    – user16324
    May 14, 2018 at 14:35
    \$\begingroup\$ Always in parallel for power factor correction \$\endgroup\$ May 14, 2018 at 14:38
    \$\begingroup\$ For pawer factor correction? No they don't, as I said - the capacitors are connected in parallel. \$\endgroup\$
    – user16324
With series components the component that presents the highest impedance IS the dominant factor that determines overall impedance. For instance 1 ohm in series with 1000 ohms is still largely 1000 ohms.
A large value capacitor has a small value impedance hence, in a series circuit, as the capacitor value rises, it's dominance becomes less and less.
Opposite for a parallel combinations of components; lowest dominates.
  • \$\begingroup\$ Ohk.. As the capacitance decreases, the capacitor acts more closely to an "open" circuit, so more voltage drops across it. So far I've been wrongly replacing the capacitor with a "short", so the confusion. Your answer is perfect. Thank you :) \$\endgroup\$
    – AgentS
    May 14, 2018 at 15:17
Try adding your capacitor here, instead. This is how facilities with large inductive loads implement power factor correction. (at least, passive PFC. Active PFC is another question entirely.)
