I found a lot of tutorial to get counter value from an interrupt timer something like:
    /* USER CODE BEGIN WHILE */
  while (1)
  count = __HAL_TIM_GetCounter(&htim2);    //read TIM2 counter value
/* USER CODE END WHILE */
Generally, this code is used with HAL libraries and STM32F4 I used the same but the function is not declared in HAL Libraries. Do you know why? What I'm supposed to use instead?
Thank you
It was: __HAL_TIM_GET_COUNTER
I should RTFM better
__HAL_TIM_GetCounter() is apparently deprecated and moved to Legacy/stm32_hal_legacy.h. If you have a lot of old code, you can put #define USE_LEGACY in stm32f1xx_hal_conf.h to include it automatically.
Firstly, go stm32fXxx_hal_tim.h file. And then you can look whatever you want to function. In my header file, __HAL_TIM_GetCounter function updated as __HAL_TIM_GET_COUNTER
I think you can use that function.
    \$\begingroup\$ Of course the OP can use that function, they already posted it in an answer more than one year ago. \$\endgroup\$ – Dmitry Grigoryev Aug 16 at 8:12
