I am learning Altium Designer and therefore I've shosen simple audio project. For the sake of Multichannel Designm I've created simple audio input port, which I am multiplying with Repeat command and here is root sheet: Root Sheet As you can see, AUDIO_INPUT is multiplied 8 times using Repeat command and here is AUDIO_INPUT "zoomed": Audio Input Sheet Now, when I try to compile the project, I get following error(s):
Class   Document    Source  Message Time    Date    No.
[Error] Sheet4.SchDoc   Compiler    Duplicate Component Designators J2 at 2950mil,5050mil and 2950mil,5050mil   20:05:54    16.05.2018  1
[Error] Sheet4.SchDoc   Compiler    Duplicate Component Designators J3 at 2950mil,4050mil and 2950mil,4050mil   20:05:54    16.05.2018  2
What did I do wrong? I tried to reannotate designators, I get same error. Nomenclature:
  1. Sheet4.SchDoc is root sheet
  2. Sheet2.SchDoc is audio input sheet
I have deleted from and placed problematic components back to schematic and now the errors(s) are gone. But can someone tell me why?
ADDENDUM:
I have forgot to tell my project is under version control and I've commited project to repository, then deleted the contents of .Annotation file (I've left the EMPTY file itself in project structure) and it compiled ok, but I hardly beleive this is the right way to fix this problem.
  • \$\begingroup\$ Try adding some connection lines on the top sheet to the ports, or maybe even to some dummy components. Perhaps the project net-list (or lack of one due to no connections) is confusing the compiler. \$\endgroup\$ May 16, 2018 at 20:15
  • \$\begingroup\$ In "Project options", change the "Net identifier scope" to "Hierarchical", and report back. \$\endgroup\$ May 16, 2018 at 20:18
  • \$\begingroup\$ @ChrisKnudsen it was already set. However, I've noticed all deisgnatiors in multichannel design were same, therefore I've deleted the parts, inserted them back, reannotated the the project and then recompiled it and the errors were gone. \$\endgroup\$ May 22, 2018 at 9:28
You probably have two components that have the same value in two different sheets, Example:
Sheet2 has
J2
J3
Sheet5 has
J2
J3
You need to rename the connectors in sheet 5 (or whichever sheet is offending)
Sheet2 has
J2
J3
Sheet5 needs to be
J4
J5
Manually check all of the sub sheets and see if any two designators are the same
If that doesn't work then designate sheet1 and sheet2 first with lower numbered designators (ie J1-J4) and sheet5 to have higher numbered designators (ie J4-J5) so when it repeats it fills in J4-J20
