Is it possible to analytically calculate Idss for JFET? I tried by setting voltage gate-source to zero, and then finding the drain current, but it doesn't seem to match with the given value?
  • \$\begingroup\$ They differ a lot from sample to sample. You're lucky to find one that corresponds to the datasheet. This is one reason they're not used as constant current sources, for example -- they're not very reliable in this regard. \$\endgroup\$ May 16, 2018 at 18:57
Yes but only if you knew the values of all relevant parameters accurately enough. And not their average value but the actual value of the JFET you're analyzing.
Problem is, many of those parameters vary a lot so it would take quite some effort to determine all those parameter values. It is much less effort to just measure the current of that particular JFET.
That large variation in current between similar JFETs also means that you should only use a JFET as a current source if you do not care much about the actual value of the current. For example if you just need a current of a couple of mA which needs to be fairly constant over supply voltage variations but you do not care much about the actual value of the current, then a JFET might be suitable in some situations.
