I am building some electronic circuits with some arduino in it to animate LED-strip.
The device is powered by 3 USB cables, because as I am using 270 RGB LEDs I can have 5A running trough the cables, so I splited it in three circuits. They are all powered from a powerbank and USB cables.
I already made a first version witch works correctly but I ended up with 4 117S switchs to turn in on.
I already found a way to lower it to 3 switchs but I do not know how to only go to only one since they are on different circuits. Because it is annoying to have to turn on 3 switch each time because the device is made to have all on them tu be turned on to work properly.
Here is how the circuit looks actually: enter image description here
Is there some 2 state switch that can have multiple outputs? Like 3 inputs and 3 outputs? Each circuit carries around 1.5A. Should I use AND gates?
I'm still new a beginner in all this, I have a programming background and doing some electronic as a hobby.
The simplest solution is to use a 4-pole switch.
Figure 1. An on-off-on type 4-pole switch. Source: Sparkfun Switch Basics.
You need:
  • 3-poles (individual contacts) minimum.
  • 1-way or single-throw where each pole is either open or closed
So at a minimum you want a 3P1T switch. A 4P1T or 4P2T (double-throw has changeover contacts).
The type in the image has a centre off position so it's probably not quite what you want.
  • \$\begingroup\$ Thank you for your answer, to be sure I understand properly. A pole is a a connection point and a "throw" is a position where the current flows ? So for me I would have to search for a 3P1T / 3PST or with more poles ? \$\endgroup\$
    – Breci
    Commented May 17, 2018 at 11:41
  • \$\begingroup\$ A pole is one switch. See the diagram on the left. There are four poles or switches actuated by a common toggle lever. Your understanding of the throw is correct. See the Sparkfun article for more. Your understanding of switch type is correct. Don't forget to check the current rating >= what you require. \$\endgroup\$
    – Transistor
    Commented May 17, 2018 at 12:13
