How can I run 12V motors with the current of 30A together with 24V 100Ah battery? Should I modified my circuit to change 24V to 12V and connect to motors? or
Should I find a battery which can change 24V to 12V directly?
Thank you all.
    \$\begingroup\$ buy a motor controller \$\endgroup\$ – user3528438 May 21 '18 at 4:01
  • \$\begingroup\$ @user3528438 The motor controller isn't necessary in my case as I am only switching on and off the motor. I will consider though if there is no choice at all. \$\endgroup\$ – Daniel Phyo May 21 '18 at 4:02
    \$\begingroup\$ Connect the motors in series or get a 24 to 12 converter. Or get two 24v motors... \$\endgroup\$ – Solar Mike May 21 '18 at 5:00
  • \$\begingroup\$ get a 12 volt battery \$\endgroup\$ – Peter Bennett May 21 '18 at 5:03
If you put your motors in series, then they share current and so torque. The speeds do not have to be equal, the sum of the speeds is controlled by the 24v supply.
Whether this is OK depends how you are using your motors.
If they are identical, and mechanically coupled, then it's quite reasonable to put them in series and run them as a 24v motor.
If you expect them to ever have different loads at different times, then use a buck converter (or one per motor) to supply them with the correct voltage.
Is each motor driving identical but independent fan loads OK? What happens if one fan becomes clogged? Then the lightly loaded one will increase speed until its torque and current matches that of the first, so may overspeed. Of course it means only one over-current limit is needed to protect both motors rather than one each.
