Looking for a clever solution (writing in Verilog)
Let’s say I have two 8 bit values, and each value has an 8 bit score, for a total of four inputs, and I want to combine the two values into one 8 bit value based on the scores. Hypothetically, the simplest way would be
((score1*value1)+(score2*value2))/(score1+score2)
However, it seems to me this is not “easily synthesizable” because of the division by values that are not powers of two.
Anyone have clever ideas to write a code that would serve this function that is synthesizable? I don’t have specific definition for this fusion in mind, but it has to be synthesizable. I am also ok with less possibilities to fuse the values, meaning that I am ok with say, only 128 ways of fusing the values
  • \$\begingroup\$ What you are describing is called weighted arithmetic mean link \$\endgroup\$ – Rokta May 22 '18 at 13:43
The most direct solution would probably be to use a lookup table for \$\frac{1}{score1+score2}\$.
That would mean that you only need two adds and three multiplies.
If you need a result every clock, you'd have a three-stage pipeline:
  • In the first stage, compute
    • temp1 = score1 × value1
    • temp2 = score2 × value2
    • temp3 = score1 + score2
  • In the second stage, compute
    • temp4 = temp1 + temp2
    • temp5 = 1/temp3 (table lookup)
  • In the third stage, compute
    • result = temp4 × temp5
  • \$\begingroup\$ But the value for 1/(score1+score2)is less than one, and I am working in binary, so how would the LUT look? \$\endgroup\$ – David May 28 '18 at 14:15
  • \$\begingroup\$ Fixed-point binary numbers are not limited to representing integers only. In this case, the output of the LUT would represent fractions in the range \$\frac{0}{256}\$ through \$\frac{255}{256}\$. When you multiply this with temp4, the high half of the product is your result. (i.e., discard the 8 LSBs) \$\endgroup\$ – Dave Tweed May 28 '18 at 14:26
