9
I need to design a circuit to delay an input signal by a given amount of time (around a second, trimmable). The delay should be set through the use of passive components (resistors or capacitors). The input signal is basically a TTL level that goes high at a certain time, stays high for some time (100ms should be nice value), then goes back low.
I cannot use a micro or other programmable device because the firmware certification process is too expensive.
I realized a working solution that uses an RC network feed into a Schmidt triggered comparator (with a fixed voltage reference placed in input against RC voltage level). I'm not very satisfied with this solution for two main reasons:
  1. the needed delay implies large caps that are pretty inaccurate;
  2. the input signal high level need to last at least as much as 'delay';
Overall requirements:
  • delay duration 1 sec +/- 500 ms accuray +/- 10%
  • The delayed event should last for a reasonable time lets's say at least 100ms (and less than 200ms).
example waveforms of input and output signals
  • 4
    \$\begingroup\$ Or you could use a shift register, if you have some suitable clock signal available \$\endgroup\$ May 22 '18 at 14:35
    \$\begingroup\$ I think you need to draw a diagram of input signal and output signal, annotated with what causes what, and what the requirements for the output signal are. It's not clear what you mean by 'signal', whether it's just the input +ve going edge, or just the -ve edge, or both, and what happens when the timing between them changes. A monostable like HC123 might be what you need, or it might not, depending on what you want. \$\endgroup\$
    – Neil_UK
    May 22 '18 at 15:02
    \$\begingroup\$ Ahem, how about the good ol' 555 timer? \$\endgroup\$ May 22 '18 at 15:05
  • 9
    \$\begingroup\$ The statement "My firmware needs to be certified" doesn't sit well with "I don't know how to delay a digital signal". Can you give us your own estimate of how experienced you are? (Seriously, writing good firmware is usually easier than designing good analog circuitry, and if the certification is a requirement for a life-critical system, I'd prefer you don't design the analog part if you don't know how to implement a delay) \$\endgroup\$ May 22 '18 at 15:41
    \$\begingroup\$ But: where does hardware stop and software begin? A very viable solution, especially if you're dealing with more than one digital signal that needs routing, anyway, and if you need to save on component count and board space, is to just design a minimal CPLD layout with an internal clock and counter, and order these parts (often available preprogrammed, even). It's configured hardware, then, not software? I'm sure your standards define that! \$\endgroup\$ May 22 '18 at 16:13
10
The Analog Devices / Linear Technology LT6993-1 (see circuit below) is a positive edge triggered pulse generator that has a resistor-programmable clock frequency and a resistor programmable divider value and polarity, with delays up to 33 seconds with ~3% accuracy.
An internal A/D converter converts the DIV input voltage into an 8 bit divider selector and a 1 bit polarity selector. The clock frequency and the divider value determine the output pulse width. Large divider settings allow reasonably sized resistors to generate long delays.
The circuit below (from the data sheet) shows how to use two of the chips to generate a delayed pulse in response to the rising edge of an input pulse. The resistor values would need to be adjusted to match your required delays. Suggested DIV resistor values are shown in the table below the circuit.
Custom Silicon Solutions makes the CSS555C, which is a 555 timer married to a wide counter. It allows you to count multiple timer cycles to use reasonably sized resistors to generate really long delays. It has a trimmable internal capacitor to tune the delays, so it doesn't even need an external capacitor.
The circuit below shows the multi-cycle monostable mode. You would need two of the chips. The first chip would generate your 1 second delay and the second chip would be triggered at the end of the delay to generate the 100ms pulse.
If you google "CSS55C price" you can find sources where you can buy the part.
mono setup
  • \$\begingroup\$ Good suggestion (I already tried NE555 but I had some issues) I'll try it again. \$\endgroup\$
    – weirdgyn
    May 22 '18 at 17:04
6
Page 14 of the Texas Instruments 74LS123 app note has an example of a digital delay circuit using both halves of the '123. You can adjust both delay and output pulse width by varying the values of Rext. If you don't need to randomly terminate the output pulse you can tie the 'B' inputs and the clear inputs high.
  • \$\begingroup\$ Sounds goods and quite simple... I have to giv this a try. \$\endgroup\$
    – weirdgyn
    May 22 '18 at 19:00
This is indeed the very standard way of implementing a delay in a digital circuit.
  • the needed delay implies large caps that are pretty inaccurate;
Well, just use a larger R, then! The delay is defined by the the product of R and C, so you can trade one for the other - and large-valued resistors are easier to get exact than large-valued capacitors.
  • the input signal high level need to last at least as much as 'delay';
So, maybe replace your ready-made Schmitt trigger with predefined hysteresis boundaries with a trigger with a high "off-to-on" threshold and a low "on-to-off" threshold.
Another 2-chip solution. The advantage of this approach is the continuous clock which can be measured and adjusted, possibly easier than timing a one-shot event.
The input pulse sets the NAND latch which removes Reset from the counter, enabling it to count. After 8 clock pulses the output goes high. The next clock pulse resets the NAND latch which holds the counter in reset, disabling it.
The other two gates form an RC oscillator, values shown should put it about 8 Hz for a 1 second delay, and 125ms pulse width.
  • \$\begingroup\$ I always upvote any answer which uses a 4017 ;-) \$\endgroup\$
    – nekomatic
    May 23 '18 at 8:54
The 74HC4538 is one I've used often. 1 second is up at the end of its range. This is a one-package deal, since it has two separate units. The first would provide the delay, and its output would drive the second, which would produce the final pulse width.
To be clearer, perhaps: the first would be configured as a positive edge-triggered unit, and its Q output would drive the second one-shot which is configured for negative edge detection. The period of the first would be one second, and the second unit would have whatever pulse width you want (within reason, of course - probably less than a second would be good.)
And if you're worried about interfacing TTL to CMOS, don't be. Assuming the CMOS is the only load on a TTL output, adding a 1k pullup resistor to +5 will do the trick with no fuss.
