I cannot solve the convolution based on \$h= e^{-t}\$ for \$ t\ge0 \$ and \$u(t) = 1-t \$ when \$ 0 \le t \le1 \$.
Every time I try I keep getting a factor with \$ te^{-t} \$ whilst the answer shows:
\$ y(t) = 0 \$ if \$t<0\$
\$ y(t) = 2-t-2e^{-t} \$ if \$0\le t\le 1\$
\$ y(t) = e^{1-t}-2e^{-t} \$ if \$t>1\$
And I get:
\$ (1-e^{-t})+te^{-t}+(e^{-t}-1) \$
After solving the integration by parts with boundaries of 0>t
  • \$\begingroup\$ \ge = \$\ge\$. Also use $$ to center your formulae. \$\endgroup\$ – Eugene Sh. May 22 '18 at 18:33
Writing down convolution product results in
$$ (h * u)(t) = \int_{-\infty}^{+\infty}h(t - v)\cdot u(v) dv $$
The parts of the domain we're interested in are:
$$t-v\ge 0 \Rightarrow v \leq t$$ for \$h(t-v)\$
$$0 \leq v \leq 1$$ for \$u(v)\$
We can then find that for \$0 \leq t \leq 1\$:
$$\begin{align} (h*u)(t) &= \int_0^th(t - v)\cdot u(v) dv \\ &= \int_0^t e^{-(t-v)}(1-v)dv \\ &= e^{-t} \left( \int_0^te^vdv - \int_0^tve^vdv \right) \end{align}$$
Solving the first integral is rather easy:
$$\int_0^te^vdv = \left[e^v\right]_0^t = e^t - 1$$
Solving the second integral requires integration by parts:
$$\begin{align} \int_0^tve^vdv &= \int_0^tvd(e^v) \\ &= \left[v\cdot e^v\right]_0^t - \int_0^tve^vdv \end{align}$$
As you get the same integration as before, you can write:
$$\begin{align} I &= \left[ v\cdot e^v\right]_0^t - I \\ \Rightarrow 2I &= \left[ v\cdot e^v\right]_0^t \\ \Rightarrow I &= \frac{[v\cdot e^v]_0^t}{2}=\frac{te^t}{2} \end{align}$$
Plugging it all in yields:
$$ \begin{align} y(t) &= e^{-t} \left( e^t - 1 - \frac{te^t}{2} \right) \\ &= 1 - e^{-t} - \frac{t}{2} \end{align}$$
This answer is off by a factor 2, but it resembles the given answer. I don't see where I was wrong.
For \$t \geq 1\$, you can write
$$ \begin{align} y(t) &= \int_0^1h(t-v)u(v)dv \\ &= e^{-t} \left( e - 1 - \frac{e}{2} \right) \\ &= \frac{e^{1-t}}{2} - e^{-t} \end{align}$$
This is again off by the same factor of 2 compared to your reference.
