I creating a project with the microcontroller STM32F101C8t. This microcontroller has an internal clock of 36MHz. My question is how to correctly set the external clock value, ie what crystal value should I use. I already set the external clock pins in the STM32CubeMX, now it is necessary to set the correct value for the external clock. enter image description here
If you are using CubeMX there is a tab dedicated to clock setup. On the left there will be a field for the HSE value. Then you either set the PLLs manually or run the clock solver.
| improve this answer | |
A common value is 8 MHz, but the chip also support other crystals in the range 8 - 32 MHz (if I recall correctly). Next you must calculate loading capacitance in order to make it oscillates stably.
A complete crystal oscillator IC can be used for the sake of convenience.
Depend on what external clock source you use, you must change HSE accordingly.
