I want to design a PID controller with the step response method, so I needed to save the step response of my model in simulink in workspace (Vout) with saved format :structure wih time, I exctracted the time value by using the command
t=Vout.time
and signal value as:
y=Vout.signals
then run the command to exctract the data to matlab:
load StepInfoData t y
so I can analyse it by calling the function plot(t,y)
and S1 = stepinfo(y,t,0.4)
but it shows the error following
Warning: Variable 'y' not found.
Warning: Variable 't' not found.
and the same for plot function. actually, I am not sure if the workspace is the correct method to save the data.
link:https://se.mathworks.com/help/control/ref/stepinfo.html#mw_cab22a5a-b8ef-49fd-b071-3e7888430c00
the model looks like:
thanks
