I have step response in open loop of my model that i stored in workspace and I want to use Matlab to obtain the: T time constant, L dead time and A (see figure below).is there a command for that like the stepinfo? enter image description here I have used it and as I am using a plant, I simulated the plant with step input and I did save the output Vout in timeseries as you showed me previously and made this script:
time=Vout.Time;  % x
Y=Vout.Data;   % y
For K, use the final value of Y
K = Y(end);
L_index = find(Y>=.05*K,1);
L = time(L_index);
T_index = find(Y>=(1-exp(-1))*K,1);
T = time(T_index);
D = diff(Y)./diff(time);
inflex = find(diff(D)./diff(time(1:end-1))<0,1);
A = D(inflex)*time(inflex)-Y(inflex);
tangent = D(inflex)*time - A;
plot(time,Y), hold on, plot(time,tangent), plot(L,Y(L_index),'*'),
plot(T,Y(T_index),'*')
it calculated every parameters (L,T and A) but the result look like: enter image description here description here does the modification i included are right despite not seeing the tangent?
  • \$\begingroup\$ I don't believe there is. For L and T, use amplitude thresholding. For A, you can estimate inflection point by the zero-crossing when using diff twice, then get the tangential line equation at the point. For Kp use final values. \$\endgroup\$ – Vicente Cunha May 24 '18 at 10:17
  • \$\begingroup\$ actually,I don't know how to use amplitude thresholding as it shows(after googling) about finding peaks or do you mean findind the 90% of the curve then 10% and trace it? if you can please develop more for the T,L and A I will be gratefull? \$\endgroup\$ – Yaakov May 24 '18 at 10:35
An example system and its step response:
s = tf('s');
SYS = 1/(s^2+s+1);
[Y,time] = step(SYS);
For K, use the final value of Y.
K = Y(end);
For L and T, use an amplitude threshold criteria. Here I consider L to be when amplitude goes above 5% the final value, and T when it goes above 63%.
L = time(L_index);
T = time(T_index);
Use diff twice to detect the inflexion point, determine tangential line slope and the negative of its linear coefficient is equal to A.
Now a plot to prove all is in order.
step(SYS), hold on, plot(time,tangent), plot(L,Y(L_index),'*'), plot(T,Y(T_index),'*')
