I'm really new to Electrical circuits so please bear with me. I studied how set latch works :firstly, input 0 then Q(let's say output and it's 0 i this case) feedback another input resulting output 0. Then if I input 1, the output Q turns into 1, as a result it latches 1.
Here's my question. How do you know that output Q is 0 in the first place even though there is only one input gets 0 (the other input is affected by the output)?
  • \$\begingroup\$ Is this a study room to find a simple answer already in textbooks and datasheets? \$\endgroup\$ – Tony Stewart EE75 May 24 '18 at 17:32
  • \$\begingroup\$ @TonyStewartolderthandirt, textbooks like to start out an explanation with, "Assume that..." and then never explain why you're assuming it. Datasheets aren't in the business of explaining basics to beginners. \$\endgroup\$ – Annie May 24 '18 at 18:17
  • \$\begingroup\$ Yes all steps in learning have pre-requisites in experience and the best tools are a web search engine and knowing how to use key words with -notthis \$\endgroup\$ – Tony Stewart EE75 May 24 '18 at 18:32
  • \$\begingroup\$ The answer here is : you never assume and use a power on Reset or set. \$\endgroup\$ – Tony Stewart EE75 May 24 '18 at 18:34
  • \$\begingroup\$ @Annie example: google.ca/…. I prefer to teach how to fish than give free fish answers unless based on unique experience. Otherwise it gets too redundant and time waster. \$\endgroup\$ – Tony Stewart EE75 May 24 '18 at 18:38
When analyzing the behavior of a latch when the inputs are in the "hold" condition you don't know what the stored state of the latch actually is. So, you assume that the stored state is a '1' and verify that all of the other signals in the latch will be consistent with that assumption. Then, you assume that the stored state is a '0' and verify that all other signals are consistent with the new assumption. If so, then you have a valid latch circuit and you've identified the input conditions that cause the latch to retain its state.
By the way, you can't make a latch from two OR gates. You need to use inverting gates such as the NOR or NAND.
