Background
I am trying to make a SPI connection between two STM32F103C8T6's.
Measurements
According to my logic analyzer I get a signal that looks ok (sending 10 bytes with values 0x55):
Results
My receiver's callback function for RX Complete also stops in the breakpoint (last line in code below):
void HAL_SPI_RxCpltCallback(SPI_HandleTypeDef *hspi)
  /* Prevent unused argument(s) compilation warning */
  if (hspi1.RxXferCount == 10)
Problem
I sent 10 bytes, however, the RxXferCount has value 0. Instead, RxXferSize has value 10, but pRxBuffPtr is empty.
Question
How can I receive the correct bytes?
Values from the register SPI1 and variable hspi1
Relevant code
Initialization (using a GPIO for defining Master and Slave):
/* SPI1 init function */
static void MX_SPI1_Init(void)
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = (HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_12) == GPIO_PIN_SET ?
    SPI_MODE_MASTER : SPI_MODE_SLAVE);
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
Main function:
int main(void)
   MX_SPI1_Init();
   _transmitter = (HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_12) == GPIO_PIN_SET ?
   while (1)
      if (_transmitter)
      uint8_t data[] = { 0x55, 0x55, 0x55, 0x55, 0x55,
                         0x55, 0x55, 0x55, 0x55, 0x55 };
          HAL_SPI_Transmit_IT(&hspi1, data, 10);
      else
         HAL_SPI_Receive_IT(&hspi1, _spi_data, 10);
Feeling stupid, but found the answer. Just want to mention it for others:
The result is NOT inside the argument hsp (.pRxBuffPtr) of the interrupt handler
but in the variable _spi_data provided by the receive command:
