I'm adding some components to an existing design in Eagle. It's currently a 4 sheet schematic. I want be 100% sure that the net I've labelled on one sheet is connected to the desired net on another sheet. For example, that the net named MOTOR_C_D2 on a FET on one sheet is in fact connected to a GPIO line labelled MOTOR_C_D2 on my AVR CPU (they are on separate sheets).
I did a Tools->Search for MOTOR_C_D2 and it only highlighted the pin on my CPU. It did not highlight the pin I have on the FET also labelled the same. I would expect that a search would highlight ALL components on all sheets of a schematic that met the search string, but perhaps Eagle doesn't work that way?
Thanks if anyone can help.
The show command will highlight a net in all views.
  • \$\begingroup\$ Thanks, that does the trick. Don't know why the search command doesn't do this? \$\endgroup\$
    – SeanLabs
    Commented May 25, 2018 at 14:21
