I have some WS2812B LED strips and instead of hooking them up in parallel, I did them in series. The lights just get dimmer and dimmer as they go on. This was my mistake.
I have a 5v 20,000mAh battery. If I were to change the battery, say to 5v and 30,000mAh or higher, would this help with the voltage drop? Would more current mean more LEDs would become brighter?
    \$\begingroup\$ More current through the same resistance means a higher voltage drop. Fortunately, that's not how current works. \$\endgroup\$ – Ignacio Vazquez-Abrams May 25 '18 at 23:13
    \$\begingroup\$ You should probably just go ahead and figure out what that mAh rating means. The answer is: no. \$\endgroup\$ – Marcus Müller May 25 '18 at 23:17
What you mean is that, while the LEDs are in parallel within the strips, you have series connected or 'daisy-chained' the strips connecting the + and - out of one to the + and - input of the next. (Data line has also been connected through.)
Yes. The resistance of the strips will cause a voltage drop along it. The longer the circuit the more voltage drop.
No. If you measure the voltage at both ends of the strips you will probably find that the input voltage is close to 5 V but that the voltage at the far end is significantly less. The mAh rating tells you how long the battery will last.
No. You want a fairly constant voltage across all the strips.
You need to run power wires out to each strip or pair of strips. You should probably daisy-chain two or at most three strips in any section. You can feed power in both ends to even out the brightness. Observe correct polarity.
I have written a little more on the topic in Flexible LED strip light.
  • \$\begingroup\$ And use the largest-gauge wires you can for power; there's no point in running power if the run itself reduces the voltage too much. Ideally use a higher voltage and use a buck regulator at each drop. \$\endgroup\$ – Ignacio Vazquez-Abrams May 25 '18 at 23:23
  • \$\begingroup\$ @Alec, thanks for accepting the answer but please unaccept for a day or two to give the Earth a full revolution to allow the whole of humanity a chance to answer your question. You might attract much better answers than mine. Then pick the best one and upvote any useful ones. \$\endgroup\$ – Transistor May 25 '18 at 23:28
  • \$\begingroup\$ @Transistor Thanks for your reply... it really helped. I also read your article. When I'm done with the step I'm on right now, I'll go ahead and see if I can hook up the 5v and Gnd to the other end of the strip to help with the drop. Many thanks! \$\endgroup\$ – Alec May 25 '18 at 23:32
  • \$\begingroup\$ @IgnacioVazquez-Abrams Yah, a higher gauge probably would've helped me out too. Thanks for your help! \$\endgroup\$ – Alec May 25 '18 at 23:37
