I tried to control servo motor by using servo library in Arduino and it is working fine. But when I use separate power supply and function generator, it is not working. It is go to end which means 180 degree.
I used SG90 servo motor. Separate power supply voltage is 5V like arduino. I used PWM 50Hz in Function generator and duty cycle 3%. If I set 1% duty cycle, it is also going to end. PWM peak voltage is 5V.
  • \$\begingroup\$ Did you remember to connect the Arduino ground and the ground to the servo power supply? \$\endgroup\$
    – JRE
    Commented May 26, 2018 at 16:08
  • \$\begingroup\$ Fist I used ardunio but second time I used separate power supply and function generator. \$\endgroup\$
    – saji indra
    Commented May 26, 2018 at 16:10
    \$\begingroup\$ The ground of whatever generates the PWM signal and the ground of the servo MUST be connected together. \$\endgroup\$
    – JRE
    Commented May 26, 2018 at 16:12
  • \$\begingroup\$ Do you have your function generator grounded to the Arduino? \$\endgroup\$ Commented May 26, 2018 at 16:28
You better check your math. 1~2ms / 20ms is 5~10% not 1%
