8
I keep on coming across a requirement for FSK carrier separation, \$1/T\$ for non-coherent detection and \$1/2T\$ for coherent detection, where \$T\$ is bit period. I understand where this comes from in the context of an optimal quadrature receiver, such as this: Optimal Quadrature Receiver for Noncoherent FSK. Now from an electronics standpoint, say I design a filter-envelope detector receiver:filter-envelope receiver In this scenario where we use bandpass filters why do we need the FSK carriers to be orthogonal? - Why do they need to have a frequency separation of 1/T? Also, if this scheme works then why is it not considered an optimal receiver system, in contrast to the quadrature receiver?
  • \$\begingroup\$ Why have you got a DAC in your 2nd drawing? \$\endgroup\$
    May 27, 2018 at 9:58
  • \$\begingroup\$ I copied and pasted this image from an example in a course handout. I'm not sure why the DAC is there either- it shouldn't be for the point I'm trying to make- i'll edit the image now \$\endgroup\$
    – snEE
    May 27, 2018 at 22:43
  • \$\begingroup\$ The output of your bandpass filters won't actually look the way you've drawn it. It's an oversimplified graph. \$\endgroup\$ May 28, 2018 at 3:24
  • \$\begingroup\$ Would you mind clarifying for me how they would look differently, maybe in the answers below? \$\endgroup\$
    – snEE
    May 28, 2018 at 3:34
  • \$\begingroup\$ I would mind, unfortunately, because then I'd have to actually simulate it and make graphs and stuff. If you think about it though - in your example you have 3 cycles and then 4 cycles per bit, and the 4-cycle filter shoots up instantly to maximum amplitude as soon as the 1st of those 4 cycles starts. How is the 4-cycle filter supposed to detect that when it hasn't even seen 1% of a cycle yet? \$\endgroup\$ May 28, 2018 at 5:43
4 Answers 4
FSK is frequency Shift Keying, a fancy way of saying the data is transmitted by frequency modulating a fixed carrier frequency. But this is not the same as FM. In FSK the shift is in discrete steps above and below the carrier frequency.
In the center point is the main carrier frequency, which is xtal/PLL controlled. The data can increase or reduce this frequency (modulation) either in analog form (FM), of phase shifting or frequency shifting above and below the center line on a vector scope, which represents the main carrier.
Quoted From Wikipedia/Orthogonality:
Euclidean vector spaces. In Euclidean space, two vectors are orthogonal if and only if their dot product is zero, i.e. they make an angle of 90° (π/2 radians), or one of the vectors is zero. Hence orthogonality of vectors is an extension of the concept of perpendicular vectors to spaces of any dimension.
That is your orthogonal part. The DSP engine counts on a balanced 'orthogonal' approach to lock onto the carrier frequency. If you shift 5% above the carrier to represent a logic'1', you must shift 5% below the carrier to represent a logic '0'. These shifts must have a mirror image 90 degrees out of phase to be valid data, separate from the carrier, which has a vector of zero. This keeps the return to the carrier frequency 'in the center' much like FM and QAM do, so the carrier is easy to filter out and lock onto with a PLL. FM is orthogonal in an analog sense, as it is an analog modulation of the carrier, but is not 90 degrees out of phase, merely symmetrical. The sum of all modulation over a second or more is about zero.
In FSK and QAM, as they are digital data, tricks can be used the same as Ethernet and PCIe does by making sure no more than 3 bits in a row are all ones or all zeros. This is done in hardware at the physical layer on both sides of the link. It prevents the carrier frequency from being 'hidden' too long by repeating ones or zeros so the DSP chip can extract the data from the carrier.
The key to this working is in fact a nearly constant change from ones to zeros and zeros to ones, regardless of the original data stream at the HAL layer.
    \$\begingroup\$ With regards to the second paragraph of your answer, could you elaborate on what you mean by keeping the carrier frequency in the center? The center of what exactly? \$\endgroup\$
    – snEE
    May 26, 2018 at 23:57
  • \$\begingroup\$ In the center point of the main carrier frequency, whabich is xtal/PLL controlled. The data can increase or reduce this frequency (modulation) either in analog form (FM), of phase shifting or frequency shifting above and below the center line on a vector scope, which represents the main carrier. I will add this to my answer. \$\endgroup\$
    – user105652
    May 27, 2018 at 0:05
    \$\begingroup\$ I don't necessarily agree with your definition of orthogonality. Let us consider this scenario, where the bit rate is 10 bits/s, the free-running frequency of the oscillator is 15Hz, and the two carrier frequencies are 10Hz and 20Hz. If we want to detect a single bit from the data stream, then we need to be able to decide whether the signal is 10Hz or 20Hz. The quadrature receiver from the above image does this via multiplication by the orthogonal basis functions and an integration over the bit period, and then performs an envelope detection to decide which one has the largest envelope. \$\endgroup\$
    – snEE
    May 27, 2018 at 0:48
    \$\begingroup\$ I don't think any equal deviation on both sides from the free-running frequency of the oscillator constitutes orthogonal signals. \$\endgroup\$
    – snEE
    May 27, 2018 at 0:50
    \$\begingroup\$ I'm not sure I understans this QAM explenation using two signals, one of which is phase modulated and the other which is amplitude modulated. At the output of the modulator, we have either one I/Q signal, or one real signal, but I really don't see where the two signals appear. \$\endgroup\$
    – AndrejaKo
    May 28, 2018 at 16:12
For data extraction. There is a type of amplifier concept referred to as "lock-in amplifier" which is very good at extracting gain and phase information associated with a known frequency.
Why is this method prefered? if you walk through the mathematics it shifts all information that is not at the carrier frequency "out of scope" by out of scope I mean away from the mean. This includes lower frequency content as well as higher frequency content. This makes it ideal for noisy environments
The principle can be seen in the mathematics below:
\$V_{sig} = Asin(\omega t +\phi)\$
\$V_{osc0} = Xsin(\omega t)\$
\$V_{osc90} = Xcos(\omega t)\$
\$V_0 = Xsin(\omega t)Asin(\omega t +\phi) = \frac{XA}{2}(cos(\phi) - cos(2\omega t + \phi))\$ \$V_{90} = Xcos(\omega t)Asin(\omega t +\phi) = \frac{XA}{2}(sin(\phi) + sin(2\omega t + \phi))\$
Filter these signals to remove the twice carrier component
\$V_{0f} = \frac{XA}{2}(cos(\phi) ) \$
\$V_{90f} = \frac{XA}{2}(sin(\phi) ) \$
via trig:
\$\phi = atan( \frac{V_{90f}}{V_{0f}} )\$ \$A = \frac{2}{X}\sqrt{V_{0f}^2 + V_{90f}^2 } \$
  • \$\begingroup\$ So I understand the concept of the quadrature receiver you are describing above- I think it is pretty similar to the first image in the post. My main question is why in the second receiver scheme we need the carriers to be orthogonal \$\endgroup\$
    – snEE
    May 27, 2018 at 23:15
Orthogonal signals are, ideally, producing ZERO correlation in the detectors not expected to match what is being transmitted. That correlation occurs over an entire bit time.
For some ideas, read about the modulation in GSM cellphones, or in MSFSK --- minimum (frequency) shift FSK.
In the second case, possibly to include the bandwidth around each frequency f1 and f2 due to switching at the bit rate.
This may be also due to the fact that first bandpass filter should have sufficient rejection at second frequency.
