What you are attempting is dangerous practice.
There are many different types of 18650 cells with different chemistries for differnet intended purposes.
A battery must be built with cells of matched characteristics; internal resistance, charge retention, charge and discharge capabilities etc.
Mixing different makes of cells within a battery is almost certain to create serious problems and unless you can be sure they are all of the same basic type and chemistry - should NOT even be considered - it could be dangerous!
You stated, "I used the module that comes with the power bank to charge the batteries separately".
First let's get the terminology correct.
So you have a single 3.6v 18650 in your hand - that is not a battery, it's a CELL.
When two or more cells are connected together they become a BATTERY.
Cell or battery overheating is an indication of improper charginng or discharging.
You used the "module" (intended for charging a battery to about 19v) to charge individual cells of 3.6v!
Is it any surprise that everything overheated?
Would anyone use a 24v truck battery charger to charge a phone battery?
If the cells got too hot to touch (more than 50C), then you have already scrapped them, chuck them for recycling.
Putting together a battery of cells without matching (balancing) them may result in some cells rising in temperature; these wil be cells with the poorest characteristics. And they will not get any better, only get worse. It becomes a visious circle and the usable time on the battery will continue to deteriate.
it's very temping to reuse cells, I do it myself on less critical applications using 3 or 4 cells. But for rebuilding a laptop battery, unless you have a good understanding of 18650 cells and good ability to match cell charcteristics, don't attempt it, the results will be a big disappointment and could be dangerous.
Better would be to buy a new laptop battery of the same voltage and with the same number of cells and swap the cells into your old battery case. At least you will then be using balanced cells.
However, you DO need to buy from a reputable source.
Remember - NEVER buy memory or batteries on ebay direct from china!
Battery manufacturers produce cells to specific intended characteristics. But the cells produced are NOT all the same. So the characteristics are tested into three categories:
The best are set aside for customer with high-end needs at high prices.
The mid range quality go to battery producers of laptops, power tools etc.
The poorest quality go for sale as individual cells on the open market.
If you want the best, go to a good SPECIALIST supplier (NOT a retailer), who can provide a set of matched cells for making up a battery. But find one who can provide the cells ready built-up with welded tags - self soldering the cells should not be attempted.
