My vehicle's ignition barrel has given up the ghost, and instead of replacing it, i want to go with a push to start system. I have already sourced a start button and only released after chucking the slip that it pulled to ground. Can you guys help me?
Relay 1:
- Pin 30: 12v From Battery with SW1 closed
- Pin 85: SW2 From Per 12v + LED(positive) on Button
- Pin 86: Goes to Relay 2 + Accessory 12v + LED(positive) on Button
- Pin 87: Goes to Ground
Relay 2:
- Pin 30: 12v From Relay 1 with SW1+SW2 Closed
- Pin 85: Needs 12v
- Pin 86: Goes to Starting Circuit
Normally the ground of the STRT pin on Button (which is push to make) will supply the 12v to Pin 86 on Relay 2 to send 12v to the starting circuit.
