I want to use this(data-sheet) electromagnetic relay given this pin-out:
But from its data-sheet I couldn't figure out whether it is normally open or normally closed. It doesn't write it explicitly.
So I have some questions regarding the data-sheet:
1-) Is this a normally open relay? What indicates that?
2-) There are also the following parameters:
What is limiting continuous current? Does that mean the relay will open if the continuous current exceeds 6A? I also don't underrated what it means for 10A in parenthesis. All 13 14 and BB bridged?? The sentence is not so clear.
3-) How come can this coil draw only 18mA at DC. I though coils have high resistance for AC voltages? Does that mean coil's DC resistance is 1.3k? Data-sheet also does not mention any peak current for when the coil is de-energized. I thought the coil will have some high current during entering to off state.
4-) Can I use this relay for application rated for nominal 10A?
