I want to use this LM311 comparator with a single supply. But these are pins called balance and strobe which confuses me. What are these for?
In a forum I read someone suggests pin 5 and pin 6 shorted for single supply operation. Should I also ground them? But the data-sheet says: "Do not connect strobe pin directly to ground, because the output is turned off whenever current is pulled from the strobe pin"
These pins should not be kept floating, but how should they be connected in case of single supply operation as a comparator or schmit trigger?
  • \$\begingroup\$ "These pins should not be kept floating" - says who? Take another look at Fig.17 on pg.15 of that datasheet you linked to - it seems you've already seen Fig.18 immediately below since you quote from it ... \$\endgroup\$ – brhans May 30 '18 at 18:55
The LM311 has lots of gain, and an output stage with massive transient currents that cause upsets to GND and to rails and to input pins.
You'll likely have oscillation. I suggest you reconsider your choice.
The datasheet says in figure 17:
If offset balancing is not used, the BALANCE and BAL/STRB pins must be unconnected. It is also acceptable to short pins together.
