My department of the company I am working at is in charge of developing a circuit for production, and security in the embedded system is a crucial requirement. The current prototype of our embedded system runs Linux on a micro SD card (with a MPU, Am335x). My job right now is to change the design into something more secure -- something that can't be easily modified by the user. However, I haven't done this in the past so I am not really sure what are the guidelines.
My thoughts so far:
Look for an EMCC chip on a BGA package with an internal layer on the PCB for the traces. That way it would be impossible to reprogram unless the user destroys the PCB. However, I am having difficulties finding an emmc chip on Digikey, apparently they are not very common and they are all sold out.
Other thing I was thinking was not using an EMMC at all but a secure NOR flash. However, I am not really sure if that would increase the development time in my department because I suppose that would require modifying the device trees on our AM335x so that it works with a secure NOR instead of an EMMC or a micro SD card.
Edit: The security requirement I am referring to on this post is related to hardware only. We are using a TPM for secure boot and a remote attestation protocol to assert the state of the PCRs remotely. All software (new firmware) must be code signed to run. Also, all sensitive data in flash is encrypted. Thus I am not worried about someone desoldering and reading the EMMC. I am concerned however, about all the communication that goes from the EMMC to the AM335x, so I need to make sure it would be hard for someone to connect a test probe to the PCB traces. And of course, reflashing the chip and/or resoldering a new one. Those are the two basic requirements I am in need of.
Any guidance on this would be greatly appreciated.
Thanks in advance.
