I am certain that for all frequencies above about 440 Hz, there is only about a few cm of listening zone within which the polarity of the audio makes any difference.
Am I wrong?
If you connect a sound speaker cable black to red, it will reverse the + and - of the sound pressure waveforms.
440 Hz is about 78 cm wave periods, 34 cm from max + the min -, and 4 kHz sound is about 8.6 cm, 4.3 cm from the wave peak to trough another, then by being to close to one speaker you change all the sound range completely just as much as using reverse polarity on one of the speakers?
