Are they same things? Don't they both output bipolar/mirrored outputs? Im confused with the terminology here.
What is the difference between dual single-ended op amp and a fully differential opamp?
  • \$\begingroup\$ Please provide any link that you can find to either parts bearing that description. \$\endgroup\$
    Commented May 31, 2018 at 16:29
  • \$\begingroup\$ Possibly related question \$\endgroup\$
    Commented May 31, 2018 at 16:32
A dual single-ended op amp is just two single-ended op amps mounted in the same package. They can be used independently of each other.
A differential op amp is one op amp with two outputs,
