I'm using an audio amplifier to produce a 15-20 kHz, 6 watt sine wave output into a pure resistive load. There are some low-frequency components to this signal that I want to remove (mains frequency harmonics). How is this best achieved? I know how to construct RC filters for signal (i.e. low) voltage circuits but not power circuits. Can someone give an answer about how I should design the filter and suggest components that may work?
You could do what they do in speakers : -
In other words use capacitors and inductors to control the frequencies that are most directed to the tweeter. There are plenty of articles on-line about this. Try searching "speaker crossover circuit".
Or you can do a similar thing with the signal before it goes into the amplifier. The signal powers are much smaller and it will be cheaper to use smaller components.
It's a bit like asking what the best car is. So, state what you want to achieve spectrally and design a high-pass filter to suit. Maybe something like this that uses an RLC: -
I've chosen values of 1000 uH, 1 uF and 40 ohms to give a fairly flat response from 6 kHz and above. You could also use an active sallen key low pass filter but now it's possible getting more complex.
However, if you want a really steep decline in those frequencies rejected below 6 kHz then multiple 2nd order filters might be needed.
\$\begingroup\$ Thanks, your simulation for the first-order passive filter looks good and is very helpful. OK, so I just have to make sure the power rating of the components is acceptable and good to go? \$\endgroup\$ – MichaelT May 31 '18 at 16:30
\$\begingroup\$ @MichaelT - it's a 2nd order highpass filter tool and is intended to be run into the fairly high impedance of an amplifier. The first circuit (speaker crossover) is more suited for power applications. \$\endgroup\$ – Andy aka May 31 '18 at 16:32
\$\begingroup\$ Confusion from where you put the quote, I misunderstood you were continuing to talk about the signal input. The LC filter for the tweeter loudspeaker in your circuit is what I need. By the way do you know why there are two capacitors for LS1 (woofer)? \$\endgroup\$ – MichaelT May 31 '18 at 21:43
\$\begingroup\$ They are high value unpolarized capacitors and in ye olde days, they were hard to get in high values so two were put in parallel to give a bigger value. \$\endgroup\$ – Andy aka May 31 '18 at 22:07
