This is a Verilog model of an array of D flip-flops with enable line along with a test bench used in ModelSim Altera:
module Register_Design #(parameter Width = 4)
    input Clock, Reset, Load,
    input  [Width - 1:0] In,
    output reg [Width - 1:0] D
    always @(posedge Clock or negedge Reset) begin
        if(~Reset)
            D <= 0;
        else if(Load)
            D <= In;
    end
endmodule
module Register_Design_Test;
    reg Clock, Reset, Load;
    reg [3:0] In;
    wire [3:0] D;
    Register_Design #(4) REG0 (Clock, Reset, Load, In, D);
    initial fork
        Clock = 1'b0;
        Reset = 1'b1;
        Load  = 1'b1;
        In    = 4'h0;
        #2 Reset = 1'b0;
        #10 In = 4'b0010;
        #20 In = 4'b0100;
        #30 In = 4'b1000;
        #40 In = 4'b1100;
        #40 Load = 1'b1;
        #50 In = 4'b1111;
        #70 In = 4'b1110;
        #80 In = 4'b1100;
        #90 In = 4'b1000;
        #100 In = 4'b0000;
    join
    always @(Clock) #10 Clock <= ~Clock;
    initial #500 $stop;
endmodule
Here is a picture of the simulation output: enter image description here
As you can see despite the Load input is being 1 which should load a new value into the D flip-flops, the output is always 0000 which is the default state at reset. What am I missing here?
Instead of using a behavioral dataflow model, I used this one and it worked just fine:
D_FF D0 (Clock, Reset, M[0], D[0]);
D_FF D1 (Clock, Reset, M[1], D[1]);
D_FF D2 (Clock, Reset, M[2], D[2]);
D_FF D3 (Clock, Reset, M[3], D[3]);
MUX_2x1 MUX0 ({In[0], D[0]}, Load, M[0]);
MUX_2x1 MUX1 ({In[1], D[1]}, Load, M[1]);
MUX_2x1 MUX2 ({In[2], D[2]}, Load, M[2]);
MUX_2x1 MUX3 ({In[3], D[3]}, Load, M[3]);
module MUX_2x1 (In, S, Out);
    input  S;
    input  [1:0] In;
    output reg Out;
    always @(*) begin
        case (S)
            1'b0:    Out = In[0];
            1'b1:    Out = In[1];
            default: Out = 1'bx;
        endcase
    end
endmodule
module D_FF (clk, reset, d, q);
    input d, clk, reset;
    output reg q;
    always @(posedge clk or posedge reset) begin
        if(reset)
            q <= 0;
        else
            q <= d;
    end
endmodule
    \$\begingroup\$ Your reset polarity looks to be the wrong way around. You're holding it LOW throughout. \$\endgroup\$ – awjlogan Jun 1 '18 at 15:43
    \$\begingroup\$ I hate when this happens :( what a rookie mistake xD \$\endgroup\$ – 3bdalla Jun 1 '18 at 15:48
    \$\begingroup\$ Upvote @ThePhoton below, and put it down to experience :) \$\endgroup\$ – awjlogan Jun 1 '18 at 15:49
  • \$\begingroup\$ Already upvoted. But what do I put down? \$\endgroup\$ – 3bdalla Jun 1 '18 at 15:50
    \$\begingroup\$ don't worry, it's just a turn of phrase that means you've acknowledged the mistake and won't do it again :) \$\endgroup\$ – awjlogan Jun 1 '18 at 15:51
In your first code sample, you have a low active reset (if (~Reset) D <= 0). And in the testbench you hold Reset low for most of the simulation. As expected this results in D being 0.
In your second code sample you have a high-active reset (if (reset) q <= 0 ) which will naturally behave differently.
