enter image description here Basically I am designing D flip flop. While doing my pre-layout simulations, not getting the output Q for the inputs. See the attached attachments. But when I tried to take the output from CLKPULSE, getting some zigzag signals. Can you share your thoughts on this.
Using Cadence environment, TSMC 180nm Tech
Output Waveforms
Schematic Diagram
  • \$\begingroup\$ Is there RTL associated with this? or, maybe, is this a structural sim... either way is this written in Verilog/VHDL? \$\endgroup\$ – CapnJJ Jun 2 '18 at 1:58
  • \$\begingroup\$ Verilog-A? I am out on this (but, I wish I knew more about Verilog-A) :/ Check/post on Mentor's verficationacademy.com \$\endgroup\$ – CapnJJ Jun 2 '18 at 3:30
  • \$\begingroup\$ All the D-FF's I have seen look rather different. Using two sets of "feed-back inverters" and transmission gates: allthingsvlsi.wordpress.coma/tag/… \$\endgroup\$ – Oldfart Jun 2 '18 at 7:47
  1. @CapnJJ I believe it is custom design with 0.18um.
  2. @Vinay: First of all you need to run realistic simulations. Find ft of your technology. Now find 0.2ft. Set the rise and fall time accordingly for input signals. A realistic input signal is shown in 3 below.
  3. A Non-overlapping two-phase clock generator with adjustable duty cycle
  4. DETFF, The Usage of Dual Edge Triggered Flip-flops in Low Power, Low Voltage Applications
  5. More helpful, Low power dual edge - Triggered static D flip-flop
  6. All the sizes in your schematics are pw, nw and rw. I think you can read up more about analog design before attempting tape out.
