Reading and writing binary files in VHDL is not straightforward, I am not sure why this is so. I think that Verilog and SystemVerilog are more closer to C. Do they have built in capability to read/write binary files? I would expect SystemVerilog to have it since it is a high level language intended for verification. However, I am not sure about Verilog at all.
    \$\begingroup\$ Yes it does. What it doesn't have is any guarantee of portability between simulators, or any files not written by the same simulator, though e.g. with Modelsim (and probably ghdl) it'll work. \$\endgroup\$
    – user16324
    Commented Jun 2, 2018 at 23:15
  • \$\begingroup\$ so what type do use to read in binary file once I have read into a line, a character? \$\endgroup\$
    – quantum231
    Commented Jun 3, 2018 at 17:04
  • \$\begingroup\$ Funnily enough I just searched "VHDL read binary files" and found this. electronics.stackexchange.com/questions/258964/… and this stackoverflow.com/questions/14173652/… \$\endgroup\$
    – user16324
    Commented Jun 3, 2018 at 21:54
  • \$\begingroup\$ yes, overworked. \$\endgroup\$
    – quantum231
    Commented Jun 4, 2018 at 3:11
I have never tried it so I just opened my little System Verilog Golden Reference Guide for the exact syntax. I found a description of $fopenbut I also found some corrections I made to the text.
$fopen( "filename" , "mode [b] [+] ");
mode can be r (read), w (write), a(append).
b is for binary
the final + is open for read and write.
fd = $fopen("example","rb+");
The following worked for me returning 0x0, 0x01 .. 0xFF from a 256 byte test file:
reg [7:0] binv;
integer fd;
integer loop;
   initial
   begin
     fd = $fopen("C:\\tmp\\hex256.bin","rb");
     if (fd==0)
     begin
        $display("Could not open file '%s'","c:\\tmp\\test.bin");
        $stop;
     end
     for (loop=0; loop<256; loop=loop+1)
     begin
        binv = $fgetc(fd);
        $display("0x%02X",binv);
     end
   end
I also had a quick test leaving the 'b' out. The reading goes from 0x00..0x19. After that it produces 0xFF. I interpret from that, that 0x1A (Control-Z) is seen as an EOF. However, as that is a Windows/DOS feature, it might well be that on a Unix/Linux system the program would even work in text mode. I would still use "rb" as it makes it compatible and also make clear to other readers of your code, that you are working with binary files
