Maybe someone can help me out here. I have tried looking all over for a push button switch that is 4 pronged and can turn on 2 separate devices at the same time. I need to be able to turn on a air pump and atomizer together. All the push buttons I have found only allow for 1 device. I am looking for push buttons that are from 10 - 20 mm. Thank you for any help to point me in the right direction.
  • \$\begingroup\$ The magic word is "DPST". Failing that, try "DPDT". \$\endgroup\$ – Ignacio Vazquez-Abrams Jun 2 '18 at 23:40
  • \$\begingroup\$ what do you want to happen when you release the switch? \$\endgroup\$ – jsotola Jun 3 '18 at 1:17
  • \$\begingroup\$ Once the switch is released it will cut both systems off. I talked to my supplier and they are able to make the correct momentary push buttons for me DPDT thank yall again \$\endgroup\$ – Timothy Bradley Jun 3 '18 at 22:20
I believe you'll need a DPST or DPDT momentary OFF-(ON) switch. Use filters on Mouser or Digi-key to search.
  • \$\begingroup\$ Thanks! I do believe that is what I am looking for! Yall are awesome! \$\endgroup\$ – Timothy Bradley Jun 3 '18 at 0:18
  • \$\begingroup\$ @TimothyBradly glad we could help. Could you please click accept this answer so I can get my street cred points? ;) \$\endgroup\$ – Avid Pro Tool Jun 3 '18 at 0:19
