I am trying to read data from a USB using CH376 module with PIC 18f4520 microcontroller.
The name of the file I am trying to read is "ABC.txt" and it contains "hello".
// Instructing module which file to read
SerialTransmit(0x57);
SerialTransmit(0xAB);
SerialTransmit(0x2f);
SerialTransmit('A');
SerialTransmit('B');
SerialTransmit('C');
SerialTransmit('.');
SerialTransmit('T');
SerialTransmit('X');
SerialTransmit(0x00);
init_lcd();
lcd_string("fn");
function_int(RCREG);
DelayMS(1);
// Opening the File
SerialTransmit(0x32);
init_lcd();
lcd_string("open");
DelayMS(2000);
if(RCREG!=0x14)
    init_lcd();
    lcd_string("open not ok");
    while(1);
 else
        init_lcd();
        lcd_string("open ok");
        DelayMS(1);
 i=0;
  // Setting to read 5 bytes
  SerialTransmit(0x3A);
  SerialTransmit(0x05); // here
 i++;
 init_lcd();
 lcd_string("dl");
 DelayMS(2);
 if(RCREG!=0x1D)
   init_lcd();
   lcd_string("dl not ok");
   while(1);
 else
    init_lcd();
    lcd_string("dl ok");
    DelayMS(1);
// Reading
SerialTransmit(0x27);
// It reads the first byte here, first byte is a waste byte i.e.
// it returns 0x05 (The number of bytes we want to read)
init_lcd();
lcd_string("0read");
DelayMS(3000);
// It reads the first byte here, i.e. H
init_lcd();
lcd_string("1read");
lcd_string("==");
lcd_data(RCREG);
DelayMS(3000);
// It is supposed to read 'E' here, but it still reads 'H'
init_lcd();
lcd_string("2read");
lcd_string("==");
lcd_data(RCREG);
DelayMS(3000);
// It is supposed to read 'L' here, but it still reads 'H'
init_lcd();
lcd_string("3read");
lcd_string("==");
lcd_data(RCREG);
DelayMS(3000);
while(1);
I am able to set up and instruct the module to open and start reading the file. But the problem is that I am stuck on the first byte. I cannot make it to read the second byte. How can I do so?
Thanks, I will really appreciate any help.
  • \$\begingroup\$ function_int does what? \$\endgroup\$
    – Dorian
    Jun 3, 2018 at 13:36
  • \$\begingroup\$ @Dorian It displays the hex value of byte, lcd_data displays the actual character \$\endgroup\$
    – prog_SAHIL
    Jun 3, 2018 at 15:51
  • \$\begingroup\$ What complier are you using? \$\endgroup\$
    – Dorian
    Jun 4, 2018 at 8:50
  • \$\begingroup\$ @Dorian, I am using MPLAB with Hi-Tech compiler. \$\endgroup\$
    – prog_SAHIL
    Jun 4, 2018 at 13:20
  • \$\begingroup\$ See more details on chat \$\endgroup\$
    – Dorian
    Jun 4, 2018 at 14:40
You cannot use RCREG in this way. You must read-it into a buffer then use the buffer for other tests.
I see you use:
lcd_string("==");
lcd_data(RCREG);
On the second usage RCREG will be the next byte received or the uart unit will show an error because there is no data in the RCREG register.
Also , pic 16f4520 does not have a receive FIFO, long delays you use lead to buffer overflow and all bytes received are lost.
Use a temporary buffer to read all bytes without delay then process the data
The right way is to:
  • read the RCIF flag to see if there is data available in RCREG
  • read RCREG into a buffer and again to first step until you read all bytes expected.
  • process the received data.
Or use a software UART buffer, if you use MPLABX then use mplab code configurator and functions generated , do not read the RCREG directly
Update. As you use SerialTransmit that waits for the TX buffer to be empty before sending a character use also SerialReceive which waits for a character to be received.
You have a combination of faults here, in the code shown above you are reading twice and the second byte read is faulty leading to a receive overrun
Then, even at my advice you buffered the RCREG , after that you have a long delay but the receive buffer of UART can hold only one byte and all other bytes are lost.
Use SerialReceive (which waits for a byte to be available before returning as you see above) and buffer all expected data before making any processing:
for(i=0;i<number_of_bytes_expected;i++)
   buffer[i] = SerialReceive();
// do whatever you need with the data
  • \$\begingroup\$ Thanks. I will try this and let you know if this works. \$\endgroup\$
    – prog_SAHIL
    Jun 4, 2018 at 3:00
  • \$\begingroup\$ I tried it using buffer but still it is stuck on the first byte. (Can we move this conversation the chat?) \$\endgroup\$
    – prog_SAHIL
    Jun 4, 2018 at 6:17
  • \$\begingroup\$ @prog_SAHIL Of course, let 30 min to get to a pc, I'm on mobile right now \$\endgroup\$
    – Dorian
    Jun 4, 2018 at 8:11
