This is my first attempt to simulate a circuit in the time domain with CircuitLab. In order to ask a proper question about something similar driven with PWM, I'd like to add an adjustable duty cycle to the square wave, and then if possible ramp it.
How can I add variable duty cycle PWM to a CircuitLab simulation within a question?
  • \$\begingroup\$ So far I haven't found anything in meta that discusses if CircuitLab assistance is off-topic, nor have I found anything in the help center for or against. Further, my previous question How to approximate the behavior of a phototransistor in the circuit editor? was answered without incident. Why the silent, anonymous insta-close vote rather than a helpful comment? \$\endgroup\$ – uhoh Jun 4 '18 at 8:33
    \$\begingroup\$ As long as we're talking about CircuitLab in general and not a detail of the StackExchange implementation, it's fine on the main site (instead of meta.EE) \$\endgroup\$ – W5VO Jun 4 '18 at 18:07
  • \$\begingroup\$ @W5VO thanks! Yep this one's strictly about simulating a circuit. \$\endgroup\$ – uhoh Jun 5 '18 at 1:06
This is an interesting question. I've never had to do it but this might work for you.
Figure 1. Two sawtooth oscillators and a comparator.
Figure 2. Note the DC offset in the sawtooth configuration.
Figure 3. The result.
I seem to have configured the amplitude incorrectly on the triangle waves. They should probably be 2.5 V with 2.5 V offset but perhaps the graph is clearer like this.
  • \$\begingroup\$ Oh excellent! Yes I've got the idea, this will work nicely. It may in fact be how it was actually done at some point. \$\endgroup\$ – uhoh Jun 4 '18 at 8:55
