-4
What are the major difference between power amplifier and voltage amplifier?
closed as too broad by Olin Lathrop, Finbarr, Andy aka, Bimpelrekkie, winny Jun 5 '18 at 7:25
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • 4
    \$\begingroup\$ Do you know the difference between voltage and power? \$\endgroup\$ – Eugene Sh. Jun 4 '18 at 17:03
    \$\begingroup\$ What makes you think there are such things as strictly voltage amplifiers and power amplifiers? It seems you don't really know what amplifiers are in general, else you wouldn't be asking this rather meaningless question. \$\endgroup\$ – Olin Lathrop Jun 4 '18 at 17:14
  • \$\begingroup\$ this sounds like a school question .... why are you asking? \$\endgroup\$ – jsotola Jun 5 '18 at 3:02
A voltage amplifier takes a small voltage signal, say in the millivolt range, and outputs a similar signal that is scaled by some multiple (the gain) of the original signal. This gain can be > 1, = 1 (buffer), or < 1.
A power amplifier, in the context of practical electronics, uses a small incoming signal (typically voltage or current) to control a large amount of power (volts x amps). "Large" is relative to the input signal; the power amplification stage of a guitar amp might only handle a few watts, while a generator voltage regulator's power stage might handle hundreds or thousands of watts.
Designers don't conceptually consider a power amplifier as a device that uses a small power input to control a large power output. As stated above, you'd input a voltage or current.
