I'm using a simple online simulator tool to build a passive Butterworth filter. An affirmation made in this page confused me:
Enter the filter characteristic impedance. In all cases, unless you specify a matching network (see below), this is equal to the filter input (source) impedance. For Butterworth and odd-order Chebyshev filters, this is also the filter output (termination) impedance
Firstly, I'm trying to understand why they made the choice of input impedance = output impedance.
Secondly, I have found that source impedance is not even present in transfer function. For example:
The transfer function of this circuit is given by
$$H(s)=\frac{R_{output}}{(L_1L_2C_1) \cdot s^3+(L_1C_1R_{output}) \cdot s^2+(L_1+L_2)\cdot s+R_{output}}$$
I see that the choices of \$R_{output}\$, \$L_1\$, \$L_2\$ and \$C_1\$ are not affected by \$R_{source}\$. So, why are there an "Optional Matching Network" where I can specify the source impedance if this will not make any difference?
I have already checked that this tool produces different circuit and component values for equal I/O (using "Characteristic impedance" field) in comparison with different I/O (using "Optional Matching Network" fields to enter impedances), but I can't figure out why my reasoning is wrong. The behavior I was expecting was, as mentioned above, no changes in components values and circuit topology when source/input impedance is changed.
@Tony's answer provides one reason for why impedance mismatching might not work, but in this case, it's about two things: analitical determination of elements' values and their simplification.
LC ladder filters (Cauer topology) need special considerations in designing them because the output of each single LC stage influences, and is influenced by the next one, starting with the input impedance, ending with the output. Since LC filters are considered lossless, making hte I/O equal means full power transfer, true, but changing them means recalculating every LC element. In doing so, there are three cases:
  1. \$R_{IN}>>R_{OUT}\$ The input is at least 10x greater than the output. For a fixed input, the output may be considered short so, for a lowpass prototype, the last element should be shunt, or a capacitor.
  2. \$R_{IN}<<R_{OUT}\$ Same as above, but shorted input (ideal voltage source) => input starts with cap.
  3. \$R_{IN}==R_{OUT}\$ This implies certain simplifications in the formulas and is, most probably, the reason it is required on the site. I say this also based on the fact that the Chebyshev filters are designed based on a radio button selecting between a few predefined passband ripples.
For example, the reflection coefficient is (I use abs() to merge the first two cases):
$$\lambda=\frac{|R_{OUT}-R_{IN}|}{R_{OUT}+R_{IN}}$$
and the elements are calculated based on the realpart of the poles and a function of \$\lambda\$ (it involves some 1-\$\lambda\$), but if \$R_{IN}=R_{OUT}\$ then \$\lambda=0\$ so the formulas simplify. The same for Chebyshev.
However, as @Neil says, in the case of even orders, due to the nature of the Chebyshev filters, the response at DC starts at 1-\$\epsilon_p\$, where \$\epsilon_p=10^{A_p/20}-1\$ (Ap=passband ripple), so, because these are passive filters, there is no amplification, and the load should have a minimum allowed value. The minimum load is found out solving the following, considering a unity input load:
$$\frac{4R_{OUT}}{(1+R_{OUT})^2}(1+\epsilon_p^2)\leqslant1 =>$$ $$2\epsilon_p^2-2\epsilon_p\sqrt{\epsilon_p^2+1}+1\leqslant R_{OUT}\leqslant2\epsilon_p^2+2\epsilon_p\sqrt{\epsilon_p^2+1}+1$$
with usually the positive (right hand) side. For input load different than 1, simply scale accordingly. Going below will not cause explosions, but the output will be distorted. Here's a simulation of a 4th order Chebyshev (type I) with 1dB ripple and fp=1Hz, for a 1\$\Omega\$ input and a step of several values for the load:
step
V(z) is the reference, and the rest are as follows:
  • V(y) calculates the filter for fixed 1\$\Omega\$ input and output, while stepping the load between these values: 1, 1.5, 2, 2.66, 3, 5 (2.66 being the recommended load);
  • V(x) calculates the filter for 2.66\$\Omega\$ output, and steps the load between the mentioned values;
  • V(w) synchronizes the filter's calculations with the output (i.e. when the output is 1.5, the filter is calculated for 1.5 output).
I also used the web page you linked and it said the output should be 2.699 (my calculations: 2.659722586382993, with rounding, most common in practise).
As for your second question, while @Neil mentions that there are cases for keeping the input, or the output, shorted, or opened, I'm afraid in this case you simply didn't place the label where it should have been placed: before the input resistance, instead of after, as it should be when calculating a diport of this nature. For that particular T filter, the transfer function becomes:
$$H(s)=\frac{R_{O}}{L_1 L_2 C_1 s^3+(L_1 R_{O}+L_2 R_{I})C_1 s^2+(R_{I}R_{O}C_1+L_1+L_2)s+R_{I}+R_{O}}$$
  • \$\begingroup\$ So, I think that my first mistake was to assume that impedance matching refers to \$ R_{IN} = R_{OUT} \$. Now, reading your answer and @Tony's, I get it: Impedance matching, in this context, is to match the source impedance and output impedance with values for which the filter was designed (values of \$ R_{IN} \$ and \$ R_{OUT} \$, respectively). Thus, \$ R_{IN} = R_{OUT} \$ was just a simplification adopted by the site tool. \$\endgroup\$ Jun 5 '18 at 17:49
    \$\begingroup\$ @ViniciusACP You haven't read everything I said, then. I said that Rin can differ from Rout, but in this case, and given the way the website presents itself, it's more of a convenient simplification in calculus. Otherwise you can just fine set Rin=75 and Rout=50 (for example), directly, without additional impedance matching. \$\endgroup\$ Jun 5 '18 at 17:53
  • \$\begingroup\$ I came to this conclusion because of this: > V(w) synchronizes the filter's calculations with the output (i.e. when the output is 1.5, the filter is calculated for 1.5 output). So I thought: "He designed the filter for \$ X Ω\$ output and is using an output of \$ X Ω\$, so here is the impedance match" PS:Yes, I have read your answer completely, multiple times. I'm sorry for not understanding it correctly, I'm doing my first Electric Circuits course, so many concepts I've learned are still not entirely clear to me, such as impedance matching. \$\endgroup\$ Jun 5 '18 at 18:21
    \$\begingroup\$ @ViniciusACP Not a problem, but remember that the example was for an even order Chebyshev (type I), and while you can physically match the I/O impedances, the response will no longer be Chebyshev, that's what I tried to show. For all the other three sweeps, only the green trace (and above) is the "real one", the rest are distorted, but, sure enough, the filter delivers; crippled, but there. \$\endgroup\$ Jun 5 '18 at 18:25
    \$\begingroup\$ @ViniciusACP Maybe you meant it the other way around(?), because that's exactly how the transfer function I gave came to be. Think of it like this: if you take Vin after Rin, then the first, intermediary voltage, at the midpoint of the T, say Vt, will simply be: Zt=XC||(Rout+XL2), Vt=Zt/(Zt+XL1). If you move Vin before Rin, it will be Zt/(Zt+Rin+XL). In short, anything before the label is discarded as being part of Vin. \$\endgroup\$ Jun 6 '18 at 5:19
That transfer function is written as Vout/Vin. Vin is a measurement after the effects of R_source, so of course R_source does not appear in the equation.
If the transfer function was instead written as power_out/power_in, where power was that available from/to a matched load, the source impedance would indeed affect the transfer function, as it affects the level of Vin you'd measure at the input to the filter, due to the voltage divider action between power coming from the R_source impedance, and the impedance the filter presents.
Passive LC filters need at least one port to be resistive to provide damping, however making both ports resistive is the norm. This is because usually RF systems usually move signals around in a defined impedance system. It's also the case that the filter response is less affected by component value variations when it's doubly terminated.
You can design filters to have one port a short circuit, or an open circuit. This is very useful when building things like diplexers. The common port can, paradoxically, be thought of as a short circuit, as its voltage doesn't change with frequency. Design high and low pass filters with final series elements into a short circuit, and connect them. It's also very useful when building an interface to capacitive input load like Pockells cells. Design a filter into an open circuit, then absorb the load capacitance into the last shunt capacitor in the filter.
Even order Cheby filters have a dip at DC, which cannot be synthesised with equal terminations, which would give unity gain at DC.
Matched impedances transfer maximal power in 2 port devices. ( by theorem of same name) However is both source and load impedance is resistive you lose 6dB in power so for transmitters this is costly so some may use 0 ohm sources for low loss from DC to breakpoint. Not having a resistive load makes the reactive filter very resonant with high Q.
So source impedance matching is "optional" but load impedance matching is desireable unless you want a high Q resonant filter. i.e. "tank circuit"
Where wave reflections can cause issues from mismatched impedances , then "conjugate matching is often used so the +/- reactance cancels out.
I made this example of a 1kHz LPF that changes if you bypass the 50 Ohm so you see the effects.
The "LCL" LPF can have a zero source impedance.
Use the cursor on the chart in link to read the attenuation. (autoscaled)
