In LTSpice, I'd like to 'soften' the 'knee' of the transition between triode and saturation curves. For a JFET, lowering Vto achieves this - but also affects the ratios of the VGS 'branch' voltages when plotting Id vs VDS.
It is possible to adjust Vto and B such that the saturation curves match measured characteristics, and various ways to get an initial estimate for Vto, Beta, Lamda and Rs from the curves exist.
Having done so, is there another significant parameter which allows 'knee softening' without affecting the ratios of the VGS 'branch' voltages?
The question here concerns modeling JFET & MOSFET devices.
However, I wonder if I am seeing a limitation of the modeling? I note that for "VDMOS" (not what I'm modeling) this link mentions - "...independent fits to the saturation and linear regions of the output characteristics."
  • \$\begingroup\$ Put a resistor in parallel? Put a resistor in series? Maybe you can draw a picture of what you don't want then superimpose what you do want. \$\endgroup\$
    Jun 5, 2018 at 14:23
  • \$\begingroup\$ Hi - I'm ideally wanting to use only the SPICE parameters. \$\endgroup\$
    – SJB
    Jun 5, 2018 at 14:56
  • \$\begingroup\$ Try playing around with lambda and Ksubthres (for VDMOS), though, I warn you, you might not get quite what you expect. I leave it to you to find out, maybe, indeed, it's what you're after. \$\endgroup\$ Jun 5, 2018 at 16:36
  • \$\begingroup\$ Is it fair to say then. The JFET/MOSFET modelling is "lacking" the Ksubthres parameter? \$\endgroup\$
    – SJB
    Jun 5, 2018 at 17:20
  • \$\begingroup\$ Related question - Does Rds = Rd + Rs? \$\endgroup\$
    – SJB
    Jun 5, 2018 at 17:22
Only a partial answer (as to "why can't I make the model look like the data sheet").
I grabbed a manufacturer model (ON semi, 2SK2394). This includes a simple SUBCKT which seems to just add tiny lead inductances and so forth.
The simulation result does not look "beautifully like" the DS curves(!) - Again, the model gives a "too sharp" knee. When compared at same size & aspect ratio, the LTSpice plot (fine resolution step) looks more 'piecewise' than the DS curves.
This point would be less obvious for another part with a more negative Vto though.
I've a feeling that - for small Vto parts - I might struggle to match both saturation & triode regions with the same model.
