http://thestowes.co.uk/images/components.jpg
Can anyone please help me identify this component. It's marked R40 515 Z5J Dimensions are roughly 6.5mm x 6.5mm x 3.0mm my verniers have disappeared but it's pretty close.
    \$\begingroup\$ Asking for help identifying a part is on topic. Asking where to buy one will get your question closed. You can edit the question and remove the part about a link to where to buy a replacement. \$\endgroup\$
    – JRE
    Jun 5, 2018 at 18:56
    \$\begingroup\$ +1 for a very good picture \$\endgroup\$
    – jsotola
    Jun 5, 2018 at 18:59
  • 5
    \$\begingroup\$ Looks like 0.4µH coil. \$\endgroup\$ Jun 5, 2018 at 19:04
    \$\begingroup\$ Component ID questions are not off topic! \$\endgroup\$
    – Voltage Spike
    Jun 6, 2018 at 6:11
  • \$\begingroup\$ You could further improve your question by adding exact dimensions, if you own a good caliper. \$\endgroup\$
    – Ariser
    Jun 7, 2018 at 11:05
If the dimension 10.2x10.2x4.7mm lines up with your component then it may be Ferrocore HCI1050-R40 which is a 0.4uH inductor. There are others in the same series with the same inductance and different size. HCI####-R40.
  • \$\begingroup\$ 6.5mm x 6.5mm x 3.0mm all very rough as can't find my verniers, very appreciated though, please if anyone else can identify it I would be most grateful. \$\endgroup\$
    – th3joker
    Jun 8, 2018 at 21:35
