I am looking to idiot proof some connectors I use, which are not intended to be hot plugged, but of course they are..
The typical problematic case is with a standard 4 pole connector I use where the pins are:
- 20V
- GND
- SDA (I2C)
- SCL (I2C)
I am using a 2mm pitch, 4 pole, JST connector (B4B-PH-K-S), where all pins are the same length so there is no certainty in order of connection, thus the hot plug issues.
I have no issues with these connectors when they are safely plugged/unplugged from the system when it is off. But they consistently have failed during unintended hot swapping.
I know many common hot plug interfaces (such as USB) have extended power pins to guarantee contact order of pins, in order to prevent damage.
I guess my question is, are there any low cost, small form factor, similar to the JST connector I am using that has this sort of feature?
Other ideas on solutions are welcome as well!
