Probably off topic.
I need help identifying a switch type.
The switch in the picture is embed in a camera to define configurations to the hardware.
I would like to use this kind of switch in a project, but i need a light.
    \$\begingroup\$ what does this mean? ... but i need a light .... i think that something was lost in translation \$\endgroup\$
    – jsotola
    Commented Jun 6, 2018 at 20:22
  • \$\begingroup\$ A light would be a Brazilian expression for help. Like, when is dark, you need a light to find the exit. Kind of a guide or explanation. \$\endgroup\$
    – ahwelp
    Commented Jun 6, 2018 at 23:28
This is the DIP switch. Something like this:
enter image description here enter image description here enter image description here Pretty easy to buy in almost every place with electronic stuff.
  • \$\begingroup\$ What about the rotary ones? What is the point? Can someone explain a little more? kenable.co.uk/images/SW03334_MAIN.jpg \$\endgroup\$
    – ahwelp
    Commented Jun 8, 2018 at 13:54
  • \$\begingroup\$ @ahwelp Simple DIP switches are just... switches. They have 2,3,4,5 etc. on/off contacts. Rotary switches have one common and several 'code' pins, while turning they connects 'code' pins to common pin creating regular combinations like binary or Gray code. \$\endgroup\$ Commented Jun 8, 2018 at 20:19
