I am working on a input array that uses a ADC (MCP3208 or something similar) to read in several analog inputs and convert them to Digital signals that go into an ADAM 6066 Module. What would I need to do to communicate the inputs from the Analog to the ADC to the Adam and read the data into a program? I want this to report to a data logger and use the relays to trigger events from the inputs. I know usually read each channel as one thing, or as my experience so far. I kinda new to all this so I am sorry if I am not being clear.
Edit:Added link to datasheet
  • \$\begingroup\$ At least have the courtesy to link datasheets for those products you mention. Why wouldn't you just buy an ADAM module with an ADC? \$\endgroup\$ – Spehro Pefhany Jun 7 '18 at 17:30
  • \$\begingroup\$ I am trying to limit the number of units I need to implore to one which is the link 'adam 6066' which only has digital inputs and 6 relays. \$\endgroup\$ – Michael H. Jun 7 '18 at 18:00
Cursory look at the data sheets (The ADAM datasheet leaves a little bit to be desired): ADAM is max input frequency of 3KHz, ADC (MCP3208) is min output frequency of 10KHz. Seems you will need a bridge to get the values from the ADC to the ADAM (reliably). Maybe use a small CPLD to do this.
e.g. ADC -> SPI Read of the ADC slave (GTE 10kHz) into a FIFO -> ADAM read/sample of ADC values from FIFO (LTE 3kHz)... repeat.
Not sure of the ADAM... those are 6 digital inputs.. so, maybe you have to send/apply the data to the ADAM and it samples it/them(?) Bottom line, it does not appear that the ADAM is capable of reading the ADC directly.
  • \$\begingroup\$ I am only sending the data to the Adam and having it foreword the input through TCP Modbus. I only said the MCP3208 because I had a few on hand from another project but I would match the frequency to the Adam for simplicity. \$\endgroup\$ – Michael H. Jun 7 '18 at 18:23
  • \$\begingroup\$ Take a look at this Analog Devices site for choosing ADCs: analog.com/en/products/analog-to-digital-converters.html Most have serial interfaces for "digital out", but a few that are >1 ksps have parallel interfaces, albeit more than 6 bits, but maybe you don't need that much resolution(?). I think you will likely end up needing a bridge, but maybe one of the listed devices will suffice your requirement(s). \$\endgroup\$ – CapnJJ Jun 7 '18 at 18:36
  • \$\begingroup\$ In reality I am using the PLC to pass the ADC signal to the interface system I would have setup. \$\endgroup\$ – Michael H. Jun 7 '18 at 18:37
  • \$\begingroup\$ The idea for this came from a post in the Arduino forum about using the (MCP3208) to get additional analog inputs to your board and I was wanting to know if this was possible with a plc like the Adam 6066. \$\endgroup\$ – Michael H. Jun 7 '18 at 19:35
  • \$\begingroup\$ Well, I don't know ADAM from Adam, but it seems to me that you are going to need to process the ADC data in a CPLD/FPGA/microprocessor (i.e. make decisions) and then, using those outputs, affect the ADAM inputs accordingly to control your relays. \$\endgroup\$ – CapnJJ Jun 8 '18 at 16:19
