Why is a minimum firing angle (>0, usually 5-15°) defined for three-phase thyristor rectifier?
I would like a technical explanation.
Thanks
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThe minimum firing angle for a three-phase thyristor is 30 degree. Below thirty degrees the thyristor is already reverse biased by the third thyristor that is already conducting. Let's understand the waveform:
If the minimum firing angle is less than 30, the circuit operates in continuous conduction mode instead.
