I'm using the AD7192 ADC for a measurement unit. On startup I do all the configuration and then set the ADC into continuous read mode by writing b'01011100 to the command register. Now I need to set one of the ADC's GPO during operation what doesn't work. It seems to me like already the write operation to the command register fails - I'm sending b'00101000. According to the datasheet(page 31) I've to send this command while the nRDY/DOUT is low, but what I don't understand is, when the nRDY/DOUT is low and I start to clock, the ADC will send the current conversion so the nRDY/DOUT starts alternating. Did I miss something?
Seems like the transition cannot be done in one step. One has to explicitely deactivate the continuous read mode first by writing b01011000 to the command register and then in a second run perform the write operation to the GPO register.
  • \$\begingroup\$ That sounds annoying to have to do that. \$\endgroup\$
    Jun 8, 2018 at 13:24
  • \$\begingroup\$ Think the issue is that if the R/W bit of the first write action to the command register is not '1' (so read) it simply ignores the command. \$\endgroup\$
    – po.pe
    Jun 8, 2018 at 13:27
  • \$\begingroup\$ I guess so but nice find +1 \$\endgroup\$
    Jun 8, 2018 at 13:29
