There are many similar questions but I didn't really find the answer I want.
I have many 2-layer boards for analogue-audio-stuff. I use both layers for routing and I have ground fills on just one layer. (mostly on bottom layer). Well it works this way but..
Why shouldn't I fill also the other layer with ground copper and connect them using multiple small stitches/vias? That would reduce the impedance between some grounding components which were connected through narrow ground paths on one layer.
(Image source: forum.kicad.info)
Do you see any reasons not to fill the both layers with ground?
