I bought a random thermistor for a circuit I'm planning to build and it turned out to be a NTC 5D-15.
I'm trying to build this test circuit:
After doing a bit of research, that thermistor resistor value is 5 ohms so I have no resistors with close values so I tried my lower valued resistor and the reading didn't change much regardless of the temperature.
Do I need a resistor very close to 5 ohms to get correct readings? Isn't the resistor value too low to be able to get correct readings?
    \$\begingroup\$ Don't buy random stuff. Design the circuit, then decide what you need. If you can't get the right parts, then make another design and repeat the process. \$\endgroup\$ Commented Jun 8, 2018 at 23:31
  • \$\begingroup\$ do research about voltage dividers \$\endgroup\$
    – jsotola
    Commented Jun 9, 2018 at 0:30
It is an inrush current limiting NTC and works like this: The normal resistance is 5 \$\Omega\$, and its resistance will decrease during the switching on of devices with an initially low input impedance (rectifier with discharged capacitor, incandescent bulb or etc.) and by the time the thermistor (depending on its size: heat capacity) has heated up and has its resistance reduced the surge is over, the NTC stays warm and therefore its resistance low and the device keeps functioning properly. Well, actually it will have a temperature between the one reached during the inrush current and the steady state current, so its resistance will definitely stay below 5 Ohm. How much below depends on the steady state current.
This NTC is not intended for temperature measurements. Try to find another type of NTC with a much higher cold resistance, like this one on ebay, so it won't 'short out' your series resistor and will give some measurable result.
In the current setup your series resistance acts like a current source of 5V/100kOhm=0.5uA (I assume your supply voltage is 5V) and although any change in voltage over the NTC due to changes in temperature should be observable when measured with a voltage measuring device of sufficient sensitivity like 0.5uA*5Ohm=25uV 3/4th scale, which is very low, the A/D-converter of your Arduino will most certainly not pick this up.
Choosing a series resistor of 5Ohm as you suggest will overwhelm the power supply of your Arduino with the more than 1/2 A it will draw, so I really advise to get another NTC (as I suggested above). The heat generated in the NTC will also definitely disturb your temperature measurement.
As 100kOhm is quite high you also should consider getting an NTC with lower resistance, for instance 10kOhm and ditto series resistor. If you go for 100kOhm, definitely filter out HF noise with an Arduino-side capacitor of about 1ms/100kOhm=10nF. This will filter out noise with a frequency roughly above 1 kHz but will still accurately follow any change in temperature of the NTC. With 10kOhm you could choose 100nF.
    \$\begingroup\$ This is blatantly incorrect. NTC stands for negative temperature coefficient (of resistance), indicating that its resistance decreases as it heats up. Further, the datasheet seems to indicate that it's for sensing purposes. \$\endgroup\$
    – Hearth
    Commented Jun 9, 2018 at 1:03
  • \$\begingroup\$ @Felthry: You are totally right, corrected. \$\endgroup\$
    – HarryH
    Commented Jun 9, 2018 at 6:34
  • \$\begingroup\$ @Felthry: but also your datasheet doesn't indicate 'sensing' as its purpose, moreover, the footer (361 Protection System) suggests more that it's a protective device, in line with what I wrote (protection against inrush currents). I gave a plus because the main intention of your comment is to inform me about my error, which worked. \$\endgroup\$
    – HarryH
    Commented Jun 9, 2018 at 6:43
  • \$\begingroup\$ The "Electriacl Properties" section (this is not the best datasheet, I'll give you that) refers to the series as "D-15 series sensing NTC thermistor" (on page 4). That's where I got the sensing purposes from. But of course, this is not a very good datasheet. Anyway, since you've corrected the error, I've removed my downvote. \$\endgroup\$
    – Hearth
    Commented Jun 9, 2018 at 13:37
  • \$\begingroup\$ I see, thanks. You're right about the mentioning of 'sensing' on page 2-4, but if you look at page 1 under 'Applications', you see "..all kinds of power cicuit proterction of electronic equipments, filament proterction of CRT, bulb and other lighting lamps..". Just saying... And spelling is not their forté. :) \$\endgroup\$
    – HarryH
    Commented Jun 9, 2018 at 18:39
