I am trying to do a project which requires me to control about 100 LEDs individually. I want to make a clock that has 6 columns of 10 LEDs that as the number in the time goes up, more LEDs will turn on. I would prefer just doing it with wires connected directly to the lights. I have looked into using an arduino, but they don’t have enough ports. Is there any way to do this? Maybe using USB?
Thanks, djtravz
  • \$\begingroup\$ What power? What's the physical arrangement of the LEDs? \$\endgroup\$ Commented Jun 9, 2018 at 19:30
    \$\begingroup\$ there is always a way, except that you have not described the project, so it is impossible to guess which way would be best. \$\endgroup\$
    – jsotola
    Commented Jun 9, 2018 at 19:36
    \$\begingroup\$ Depending on power requirements, and required speed, you might just need 20 pins (hint: 20 = 2*sqrt(# of leds)). \$\endgroup\$ Commented Jun 9, 2018 at 19:38
  • \$\begingroup\$ I updated the post @jsotola and Jonathan \$\endgroup\$
    – djtravz
    Commented Jun 9, 2018 at 19:43
    \$\begingroup\$ " I would prefer just doing it with wires connected directly to the lights. " That would be 100 outputs. You know there are more efficient ways. Also 6 columns of 10 LEDs I get to 60 LEDs, not 100. \$\endgroup\$
    – Oldfart
    Commented Jun 9, 2018 at 19:47
A few choices:
  • You can use shift-registers such as HC595 to drive individual LEDs, one resistor in series with each. Needs only 4 port pins from your MCU, but n resistor and n/8 (rounded up) chips. It would be static drive.
  • You can use individually addressable RGB(W) LEDs and add color to your project. Still only a few port pins. Libraries are available for this purpose.
  • You could build row and common drivers and multiplex the LEDs fast enough that they appear to be steady. Time-tested approach, works well. You could use (say) 8 column drivers and 8 row drivers to control 64 LEDs.
Personally, for a hobby project, I would probably pick door #2.
    \$\begingroup\$ Door #2: There are Arduino libraries for the very common & cheap WS2812 LEDs. \$\endgroup\$ Commented Jun 9, 2018 at 20:54
  • \$\begingroup\$ The RGB LEDs which Wouter is referring to include a driver chip with serial (and daisy-chain-able) interface. Thanks to China they are very affordable, thanks to open-source libraries they are easy to use despite the somewhat arcane interface. \$\endgroup\$ Commented Jun 9, 2018 at 21:16
  • \$\begingroup\$ Or option 4, build a matrix with discrete row and column drivers (demux for one, shift registers for the other). Could even use a counter to drive the demux, or use a shift register and only shift by one position at a time. More efficient in terms of IO pins. \$\endgroup\$ Commented Jun 9, 2018 at 23:26
These two solution also have dimming.
Use a matrix design like the Texas Instruments 96 LED driver: LED17 1596A 96-LED Matrix Driver (get some free samples)
If you were to use a 3 output serial RGB drivers like the
Texas Instruments TLC59731 3-Channel, 8-Bit, PWM LED Driver With Single-Wire Interface
or WS2811 , you do not have to use the 3 channels for RGB but rather any 3 LEDs.
EDN Tips and tricks for driving WS2811 LED strips
