...and a few other things. I am working my way through Geoffrey Brown's book Discovering the STM32 Microcontroller and it's largely been smooth so far. I've come across an exercise where the reader can try to read/write to an EEPROM over SPI. I've had the SPI interface working in loopback, although last night when I was testing it, I noticed that on the logic analyzer I was seeing the NSS pushing high before the message was complete. Then in the morning, no changes, everything is working fine again. OK.
I set up everything to read/write the ROM (Micro 25LC256) but the signal I see on the analyzer isn't what I am expecting. I see the NSS pushing high from time to time in the middle of communicating. Further, the clock looks inconsistent and the data looks wrong, and the analyzer is giving me a ton of errors.
I thought, OK, I will take off the NSS altogether as the ROM is the only thing hooked up anyway, then it will stay low and I can check it out. But still the clock looks wonky... I'm just getting started with this stuff, but I don't have anything adjusting clock frequency at all, so not sure how thats changing? The code can be found here, and I think it's quite simple. most of the important logic looks like
// Drop select level low then send the write enable flag
GPIO_WriteBit(EEPROM_PORT, EEPROM_CS, 0);
spiReadWrite(EEPROM_SPI, res, cmd, 2, EEPROM_SPEED);
GPIO_WriteBit(EEPROM_PORT, EEPROM_CS, 1);
Delay(1); // Debugging aid, Wait 1 ms to make analyzer easier to read
I have all the speeds set low (the SPI CLK/MOSI/MISO are 72 / 64 = 1.125
< 10Mhz
= 25LC256 max speed and the GPIO I'm using for NSS is 2MHz), and I put in a delay of 1ms
between operations just to make it easier to read on the analyzer, it doesn't seem to affect the output.
Here is a capture of the analyzer data with the NSS forced low (unplugged):
Zooming in on the first pulses I see that the clock width is all over the place, doesn't look like CPOL/CPHA = 0/0 to me, and doesn't look like it's sending the write enable value WREN = 0x06 = 0b0000 0110
...and it doesn't seem to get better...
And one last one that shows the NSS pushing high for no reason
How do I debug from here? Is there something obvious that I'm overlooking? Is it common to have such bad looking timing problems? Thanks!
< 2MHz
signal? \$\endgroup\$0x06
which is the write enable value), but it's not even getting that far. As for the hold pin, I will double check in the morning, but everything is pretty simply connected on it's own breadboard, so I'm pretty sure that it's connected well. \$\endgroup\$
