I am using a recompiled version of the GCC toolchain for the ARM platform, called Yagarto. The compiler comes with a "standard library" called Newlib, and "standard headers", such as stdio.h.
For my project, the licencing of Newlib is not suitable, so I have used a printf function from somewhere else. The problem is that it seems the build-in header files are implicitly included in every .c file, and I'm getting the following error:
c:/yagarto4.6.0/lib/gcc/../../arm-none-eabi/sys-include/stdio.h:182:5: error: conflicting types for 'printf'
Is there a way to have Yagarto not load the standard libraries by default?
  • \$\begingroup\$ Can you just remove/rename the original standard libraries? \$\endgroup\$ – Connor Wolf Aug 14 '12 at 22:34
From the GCC man page:
-nostdinc Do not search the standard system directories for header files. Only the directories you have specified with -I options (and the directory of the current file, if appropriate) are searched.
-nostdinc++ Do not search for header files in the C++-specific standard directories, but do still search the other standard directories. (This option is used when building the C++ library.)
Other options would be explicitly referencing the header files you do want to include, specifying their directory with -I (which is searched before the standard includes). Or you could simply remove (or move) the incompatibly licensed headers' directory from the installation.
You may also want -nostdlib to the linker.
| improve this answer | |
  • \$\begingroup\$ Thanks. Do you know if there is a way to only ignore the header for printf? \$\endgroup\$ – Randomblue Aug 14 '12 at 16:30
  • \$\begingroup\$ If you are trying to avoid the library, why do you want it's headers? Even if only for technical reliability I would think you would want to entirely exclude dependence on them, in favor of your own with content you can more easily track. \$\endgroup\$ – Chris Stratton Aug 14 '12 at 16:36
